avatar_Floyd
Rallye Wheel Inspection Markings?
Started by Floyd, April 17, 2019, 05:27:12 AM
Floyd
While prepping my Rallyes for resto, I found some markings on the back that I hadn't noticed before. Anyone ever seen this type of marking? I expect they're factory or manufacturing markings, but I guess you can't rule out some one doing something at a tire shop. These are original paint, matched date of 5/5/70.
Couple other anal tidbits. There's some red paint residue from the drum paint on one rim and one still has the white dot valve stem cap. Pretty cool..
I can't recall any marks like them. Looks like factory style pencil though. I could see a tire shop checking for runout and marking high or low spots but not likely they would use a marker like that.
You might call those white dot valve stem caps but thats not a cap, it's an extension.... You can put air into the tire through the extension...
Looks like USA wheels not Canadian....
Floyd
Right.  That's because of the trim ring I imagine.
js27
When I worked at the Chrysler/Plymouth dealer in the 70's I put thousands of those extensions on. Hup caps / Trim Rings usually came in the trunks on new cars so they didn't get stolen in transit.
JS27
