avatar_Those
Rear axle gaskets
Started by Those, February 09, 2019, 12:29:46 PM
Those
Hi guys, need some help on axle gasket install order. Does the foam gasket go between the axle housing and backing plate the metal one between the axle flange and in front of the backing plate? I've read some people say one way and some the reverse order. Thanks
Steel between the housing & backing plate
Housing - steel gasket - backing plate - foam gasket - axle shaft flange - nuts  :alan2cents:
