avatar_Marty
1970 Barracuda Reanimated.
mtull and 5 Guests are viewing this topic.
cm
Looks like where the 71 gullwing would mount
Marty
#286
Quote from: dodj on February 27, 2025, 02:16:10 PMThat sublime Challenger....is the spoiler mounted in the correct place? Seems kinda far forward.
The owner did say he installed the wing and did use the brackets. Other than that, I thought the same thing.
Marty
It took me three tries to get the stain (Walnut Mini Wax) close to what I thought was acceptable look. Once dry, which took a day or two, I sprayed on three coats of clear coat.
After looking it over, I just didn't care for it. Instead of cutting and buffing it, I just scrapped the whole idea of using it. Instead, I bought a Rim Blow steering wheel.
The steering column was sand stripped, and a couple coats of acid etch primer applied. The column was then finished up with two wet coats of SEM Landau black.
It's been a month and a half Marty.... :popcorn:
Marty
 :unbelievable: I didn't realize it had been that long.
Ok then...
Finished up the steering column. I connected the column wires with the AAW wire connectors. Located a 3-inch steering coupler with rebuild kit. The letters on the flasher knob were also detailed. I used a piece of a business card wet with white paint from a paint pen. I lightly tapped the letters till they were covered. It took a several times to get it right. If it didn't look right, I just wiped it off with lacquer thinner and tried again. Once I had it, I sprayed on a coat of 2k clearcoat.
Installed the column assembly. I did use the coupler clip since the seal did come off while trying to install the coupler onto the steering box.
Wired up the front-end lighting system.
The right door window was just sitting in the tracks but not connected to anything. The regulator was in place but that's about it. I removed everything out of the door to see what I had and didn't have. First thing was to remove all the old single stage paint overspray. I was missing the horizontal track, a washer and the hardware that connected the track to the window.
I dug into the spare parts and found the track and the washer. I have a 71 Challenger in the paint area, so I looked at the track and was able to match the hardware. Installing the window was a breeze.
*Hardware size-Front/Phillips screw 1/4-20. Rear/ Bolt 1/4-20, 7/16 head with washer. Slot in track goes to the rear.
Marty
Door panels.
Scrubbed down the door panels with Ajax, water and a red Scotch-Brite. Rinse and then I let them dry overnight.
Wiped them down with an alcohol and water solution. 80/20. Tack cloth then two wet coats of SEM Landau black. Let them dry overnight.
Using 3M Strip Chalk, I put the moisture barriers onto the doors.
Installed the door panels onto the doors using new parts and hardware.
mtull
Quote from: Marty on May 05, 2025, 07:17:30 PMInstalled the door panels onto the doors using new parts and hardware.
Looking good Marty.  Your getting so close to being able to drive it!  How did the new hardware work?  Hopefully no issues using new vs. original?
Marty
It won't be long now.
Armrest, armrest brackets, finger cups, interior door handles, Cuda badge, lock levers, cranks, and the lower door panel clips all fit on the door panels that came with the Barracuda. No issues at all.
Marty
Short update.
Adjusted the rear disc brakes and got them at 1/16" from the stop. CPP Performance universal cables were used to complete the parking brake system.
Installed the trunk/gas tank vent lines.
Bench bled the master cylinder.
Marty
Continued...
Marty
Tying up loose ends on the Barracuda before the next phase of the engine and drive train install. So, about two thirds of the Barracuda is finished.
I had issues with the aftermarket seat tracks. They would bind up when adjusting the seats. I got the driver's side to work eventually. While trying to get the Passenger track to work, the ball bearings fell out. I didn't want to mess with it anymore so into the junk pile it went. I located a used original pass/outboard track, cleaned it up and installed it. The seat adjustment works now.
Cleaned up the engine bay and installed the last of the small parts.
Deep cleaned the paint using a clay bar then I ceramic coated the paint.
I rolled it outdoors to see how it looked in the sunshine.
It's been just over five years now. It should be done by the end of the year.
Marty
Before and after.
mtull
Awesome work avatar_Marty @Marty, looking great!  Exciting to see the progress.
"Oklahoma is OK" was the state slogan back then?!?  Or were they just trying to get people to use the short form?
Looking good Marty!
Marty
It may have, way before I got here.
Thank you!
