avatar_torredcuda
Fried fish - rebiulding and upgrading the Barracuda
Started by torredcuda, May 24, 2020, 10:16:43 AM
torredcuda
Quote from: Swamp Donkey on January 15, 2021, 09:15:25 PM
Just watched the video.  Seats look good in there!
Can`t wait to see them after I send them to the upholsterer for new covers to match the factory pattern.
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
JonH
Are you going to have the side bolsters made a little smaller, or do they not bother you as get in and out of the car?
torredcuda
Quote from: JonH on January 16, 2021, 07:33:39 AM
I thought about trimming them down a bit but being scrawny I don`t think they will bother me so I`ll probably leave them as is.
JunkYardFind
www.JunkYardFind.com What's In YOUR Garage ?
MOPAR MITCH
What is that round hole in the front core support (passenger side)?
torredcuda
Great work on the seats.  How difficult was the modification so it would tilt forward more?
I've got a line on a set somewhat local but the driver side bolster is in poor shape on the seat bottom from entering/exiting.  I'm not an interior guy, but you've have the cover off, do you think that bolster foam and the vinyl cover could be repaired by a handy person?  I have a sewing machine and can stitch by hand pretty well.
MOPAR MITCH
It looks like about a 2.5" or 3" diameter hole was cut open... next to the radiator core opening... on the passenger side (see your first page with the pics).
torredcuda
Quote from: gzig5 on January 29, 2021, 07:04:52 AM
My seats are at the upholstery shop and I forgot to get pics of the modification I did to get them to tilt forward more so I`ll try and describe it. Bascically the limiter that stops the seat coming forward is the blot that attaches the top and bottom frames together, there is a bushing sandwiched between the two plates the the adjuster teeth plate hits. What I did was remove the bolt and then weld a small piece of metal to hold the two plates together. That mod allowed the seats to come forward more as seen in the video. You could get more forward tilt out of them if you needed it but you would have to modify things a bit more but with the seat slid forward ont he track I think there is plenty of room to get in the back .
torredcuda
Quote from: MOPAR MITCH on January 29, 2021, 11:37:01 AM
Not sure, I thought it was a factory hole as it doesn`t look cut. Anyone else have a pic of `72 up 22" radiator support?  :dunno:
Quote from: torredcuda on January 29, 2021, 01:19:26 PM
I just looked at my 73, it's in about the same state as yours up front. I have a 26" radiator support and it does not have that hole, nor does it have room for that hole shown in post #5 of this thread.  You must have a 22" or smaller radiator opening.  I'd guess it is factory. I do have the rectangular hole on the driver side.
No not factory. 74 and it is solid on passenger side.  Rectangle opening for wiring on drivers side.
Mine was actually a 19" rad. But opening is same as 22".
Not a good pic. But no hole. It's a solid panel.
torredcuda
Engine bay almost ready for primer
torredcuda
Orange again! Once it's dry enough I can black out the radiator support and undercoat the wheel wells. Next I'll start building the engine/transmission dolly. I need to order some more parts and get my headers recoated before I can start assembling .
Skid Row
 :bigthumb: Like your inner fender braces, Did something similar on my 73 Challenger under my factory ones.
