avatar_GoMangoBoys
Clutch switch source
Started by GoMangoBoys, April 04, 2021, 07:23:31 AM
GoMangoBoys
Does anyone make an aftermarket replacement for the clutch safety switch?  Our car has none as we are converting from auto to manual
Try Oreillys...Part #: 8486-05.
The Oreilly's part mentioned by Don above would be a good start to a DIY project as well  :thinking:
Dmod1974
I literally made a write up last month a page or two back on this sub forum on how to make a readily available, $20 clutch switch similar to above to work without having to drill, cut, or modify the factory pedal set up at all.  It has step by step instructions with pics and the (short) parts list to do it.  Might want to check it out...
