avatar_gaddied
Does any company make a Cuda turn signal flasher bracket
Started by gaddied, June 14, 2020, 07:35:18 AM
gaddied
Does any company make a repo turn signal flasher round bracket (holder) for my 70 Cuda ? My flasher is just hanging in the air loose.
You mean this little guy ? There should be two per vehicle, one clipped on the outside of your ashtray and one on the side of the pedal assembly housing. They're designed to hold the round and rectangle shaped flasher units.
I don't they they are reproduced, but are fairly easy to find used...They were ALL the same across the board. :twothumbsup:
https://www.ebay.ca/itm/CUDA-CHALLENGER-GTX-CHARGER-CORONET-DUSTER-ASHTRAY-FLASHER-RELAY-CLIP-RETAINER/202963838670?hash=item2f419666ce:g:b3wAAOSwGx1ZxlfQ&vxp=mtr
gaddied
Quote from: anlauto on June 14, 2020, 07:48:03 AM
I don't know if that's the one , it's missing of the pedal housing . Can someone post a photo of one on the pedal housing ?
Jay Bee
While my car is still gutted at home...
Thanks John, I was trying to find pictures of un-restored ones. I have plenty of pictures of ones I've restored but that doesn't prove they were original....
:worship: :clapping:
Floyd
Got a pic of the ashtray one from an unrestored car?  Reason I ask is the original one on the pedal assembly of mine was coated with Zinc Chromate green.  You can just see the green on the pics Jay Bee posted.  Wondering if the ashtray one had the same coating or if it had something else.  The original I have looks like a gray phosphate.  Pretty anal retentive question, but what the hell...
gaddied
Thanks everyone for your help ! This really helps me out on this.
Quote from: Floyd on June 14, 2020, 09:26:04 AM
I have found both types of plating at both locations, with no real pattern  :alan2cents:
CudaMoparRay
