avatar_733604bbl
Dome light
Started by 733604bbl, January 12, 2023, 02:07:06 PM
733604bbl
Reply #2 on: September 19, 2019, 06:00:55 PM
Hello all, if you don't mind can you revisit this thread? Dome light connector is also in trunk and has power.
Where do i connect this connector for dome light to work?
73 V8 AT
Please see attached pics
Your dome wire coming from the light plugs into here (red circle)
733604bbl
Sorry for lack of knowledge regarding electrical work. So the pink/yw wires from the dome light between light and head liner goes where?
To the door switch then the trunk?
Thank you :unitedstates: :canada:
The tail light harness that runs from the DS door post along the rocker to the tail lights has the power supply for the dome light. It is the pink/yellow wire you currently have plugged into your optional trunk lamp.
The trunk lamp has a little jumper harness as shown in your picture so that it (the trunk lamp) can share the power supply with the dome light.
The wire coming from under your headliner, from the dome light plugs into the plug I circled in red.
733604bbl
