avatar_Claudia
First time gauge/dash install - please help!
Started by Claudia, June 10, 2017, 02:22:01 PM
DeathProofCuda
@Mrbill426 - did you catch the pdf file with directions from RT Engineering that I had attached in the previous clock post?  It is very well detailed with pics and goes through the process step by step.    I'm no electronics guru and found it pretty easy to do with a minimum of tools.  Here is the pdf again if you missed it previously.  Click on the link below.
Mrbill426
@DeathProofCuda thanks again I will take a look  :bigthumb:
Quote from: DeathProofCuda on September 15, 2020, 07:40:45 AM
