avatar_ToxicWolf
High Output Alternator Question
Started by ToxicWolf, May 24, 2018, 07:27:33 AM
ToxicWolf
Quote from: RUNCHARGER on May 25, 2018, 06:40:39 PM
The idea sounds neat all right. That should clean up the engine bay pretty good although then you have a big butt alternator.
I think it looks a lot better with everything tucked away and hidden.
I don't know the kind of current your ac is going to need,  but make sure your wire and connectors are upgraded to handle the amps.  Otherwise,  things will melt.  If you haven't already,  you must bypass the ammeter and bulkhead connector.  :alan2cents:
ToxicWolf
Quote from: dodj on May 26, 2018, 04:09:41 AM
Absolutely true. Ammeter conversion was done early on because I just don't like the idea of amps going through there.
That looks good, a Hemi isn't supposed to have an A/C compressor hanging on the top of it. I would consider doing that I think.
