avatar_Mopsquad
Upgrading Alternator - Ammeter Bypass and Fuseable Link Q's
Started by Mopsquad, June 17, 2019, 05:47:39 PM
MOPAR MITCH
Thus one-wire alternator setup still interests me... just installed the Denso ~65amp smaller unit... removed the Voltage regulator... wiring next.
Wondering if there is a replacement harness for this setup?
Not sure why you would want a 1 wire system , the regulator fails & you need to service the alternator vs a $20 regulator
I do not now of a plug & play wiring harness for 1 wire
Quote from: Chryco Psycho on May 17, 2020, 07:16:38 PM
I was wondering this myself. Why do people like the one wire setup over the three wire? Is there better selection of alternators? Or better performing alternators?  :dunno:
I had a custom alternator built , it put out 180 amps max , it could have been internally regulated but I chose not to do that & just run a external $20 reg instead
MOPAR MITCH
The Denso alternator is lighter... almost 7-8 pounds.. that's off the front end... less weight = faster overall performance, better handling, etc etc.   Every little bit of weight reduction adds up.  That's the bottom line... lighter weight (and a better output vs the factory units).   AR Engineering created and sells the brackets, etc.
