Wipers only work on high cuda 71
Started by Meyer, September 01, 2020, 01:39:00 PM
Meyer
2 speed wipers first step no action but full speed on 2 ?
Meyer
What wirecolour on the wipermotor is the slow speed??
Jay Bee
Lots of good info in this thread
https://forum.e-bodies.org/electrical-and-audio/11/please-help-with-2-speed-wiper-motorwiring/377/
Reply#7 has a link by passion4mopars to bench test the wiper motor. If everything works then the switch is suspect.
Meyer
The wiper motor hasa number i have been googled, it says 3 speed-variable... but the switch is a 2 speed ... what switch do i need
Ns1aar
Has this system worked in the past. If so check all your grounds including the switch. Does the switch have 2 solid clicks or a click and a clockwise sweep.
you can contact me if you like been doing this awhile
ns1aar.com
somerbr1@aol.com
 :iagree:This guy knows what he is doing, trust me.    :yes:
Meyer
Meyer
Is the 3 speed and the variable switch wired the same/same connector...
Ns1aar
No they are not 2 entirely different connectors and pin out
Jay Bee
My favorite comparison picture. Courtesy of Slotts I believe.
Clicking on the pic enlarges it to read the tags better.
Meyer
Here is the switch connector, i checked the wires from connector to bulk and its fine. But the blue wire is missing in the wiper motor harness ant to the bulk ! I have the 3 speed switch since its a 3 speed motor and the connections on the switch is ohmed out and no issues there but it still doesent work , ground the switch panel to the battery neg
Jay Bee
Are you saying you only have 3 wires in the wiper motor connector instead of 4.
Here's my 3431077 variable speed wiper motor before going into the car.
Meyer
Meyer
