1970 AAR 4 Spd Question
Started by FIAARMN, August 16, 2020, 10:23:36 AM
FIAARMN
So, the car as most may know has been sitting a while. But when it is off and parked we have been going from N to R for the key and doing all we are doing there may be an issue.
Its just really hard to get into reverse and out of.........   are there any adjustments?  Places to look at or things?
1970 AAR Cuda Limelight Green,White Interior, - Hamtramck Built 36k miles, Verified All Numbers Match - Broadcast Sheet, Warranty Card & Window Sticker!
The shifter probably needs to be throughly cleaned & re-greased, but even just adjusting it may help....
FIAARMN
Quote from: 1 Wild R/T on August 16, 2020, 11:19:00 AM
Any good thread or right up on how to adjust?
Jim AAR
If You haven't you should download the 1970/71 Plymouth service manual that is on this site, it has everything you need and lots of pics.
I have it on a tablet I use in the garage. It's in the resources area on here.
Likely stiff from sitting so long :dunno:
I find the reverse levers are quite often loose (as in the nut is backed off) or the hole in the lever is elongated. Just 2 easy things to check.
