avatar_garrett007
340 Engine Mount Brackets
Started by garrett007, July 02, 2018, 06:00:54 AM
garrett007
I am working on installing a 340 into my '70 Challenger.  I did not remove the engine, but now I am trying to figure out the correct way to install the motor mount brackets on the block.  Which way did the factory install the six bolts?  The manuals I have looked at do not show the bolts.
70' Challenger - running
I can't help you with your question but welcome to the site. Someone here will have the answer for you.
I don't know what is correct, they will work either way.  But, mine are installed from front to back, meaning the bolt heads face the front of the car, nuts go on from the back of the car towards the front.
BIGSHCLUNK
I could get you a pic of the 340 in my Dart.... if that helps?
76orangewagon
Quote from: gzig5 on July 02, 2018, 07:11:00 AM
That is the way mine are ....all three bolts per side face the firewall and the heavy stamped bracket goes to be back side of the cast mounting ears/tabs on the block.
bentpshrods
  Here's a pic of mine when I pulled it out this spring. So I wouldn't forget.
76orangewagon
Like the above post here's a couple pics I took so I won't forget later after the rebuild.
garrett007
Thanks for the pic, just what I was needing.  Here is how they look.
nsmall
How about some more engine pics?  Looking great!
garrett007
Thanks,
Nice job on the engine!!!   :clapping:   :1place:
It may not matter...I doubt mine was tampered with.
The bolt threads should face the grille, not the firewall. Only exception is pass side rear top mount bolt which faces the firewall.
Replaced OEM mounts last weekend recently on a virgin A66.
73_Cuda_4_Me
Here is my 73 parts book drawing page for mounts...
BS23H3B
