6an fittings
Started by 61K T/A, August 01, 2017, 08:22:38 AM
61K T/A
I installed a stacked plate power steering cooler and dont like the angle of the PS hoses when connected. I found these push on hose fittings. I like the idea that they are clean looking, simple, and rated at 250psi. Any one use some thing like this?
https://www.summitracing.com/parts/fra-204506-bl
I think there is special hose made for those style fittings.  I don't think you can use regular hose.  They make a special lube in order to get the hose installed.  If you don't use that lube, it SUCKS!!! trying to install the hose.
61K T/A
This is on the low pressure side of the pump. 2000psi may be overkill. There is also a crimp on sleeve you can use or just a hose clamp.
Quote from: 61K T/A on August 01, 2017, 08:52:49 AM
Ah, ok ya then the ones you linked will work.( be sure to use hose rated for power steering fluid, NOT fuel line) But then so will a hose and hose clamp....
61K T/A
Quote from: Burdar on August 01, 2017, 08:30:51 AM
I was thinking about using the Teflon lined hose.
As mentioned, do not use regular AN rubber hose for the -high pressure- side of the power steering system.
That being said, you mentioned using a cooler. That cooler should be installed on the -low pressure- side. For this instance, the rubber AN hose IS sufficient.
I used teflon braided hose on the high pressure side and pushloc rubber hose on the low side.
