8 3/4 Rear pinion seal leak - repair questions
Started by 72 Challenger, Today at 06:45:06 AM
Skdmark and 4 Guests are viewing this topic.
72 Challenger
Hi Everyone,
Looking to put my 1970 Plymouth Duster 340 up for sale in the spring and move onto another mopar. Underneath it is a factory 8 3/4 with a 489 case. There is a slow rear pinion leak I Would like to fix prior to the sale as it's messing up the paint underneath the car.
Is there a preference for pinion seal? I am on Rock auto and see there are several brands, are there any we know that are prone to being bad?
What oil weight are we using in rear ends? Brands, recommendations?
I know about the friction modifier, I will pick one up from the dealer. Some people say the ford one is better, is this true or bogus?
Is there a gasket between the differential and the case? or is that just RTV?
Thanks team!
Someday I will have a J0b.
I think it was a National seal I used in my 489, but there's lots of choice out there. Theoretically you're to change the pinion crush sleeve when you do this, but I marked the nut/pinion, counted the number of turns the nut made and reassembled it back to my marks and had no grief. Grease the seal's inner lips. Fluid I think I used 85/140. The Ford additive also went in mine and yes, there is a gasket between the "pumpkin" and the case. If you remove the pumpkin, make sure you do a really good job cleaning the mating surfaces. I put a light schmear of "The Right Stuff" on both sides and have zero leaks. Have fun!  :bigthumb:
I would change it in the car however if you pull it out I also clean the wheelbearings and repack them too. It snowballs....
72 Challenger
Thanks guys! I Was going to replace it in the car but I am going to replace the carrier to differential gasket at the same time. I will also count the turns and forego the crush sleeve.
Re-packing bearings is not a huge deal either.
