avatar_THE ZUKE
A little water pump leak ...
Started by THE ZUKE, December 30, 2018, 01:10:13 PM
THE ZUKE
Quote from: Chryco Psycho on March 09, 2019, 09:36:24 PM
the casting differences around the mounting holes affect nothing ,  the squared casting goes to the top on both
Thanks @Chryco Psycho  ;)
Ok  :bigthumb: so exactly in the same direction as my pictures.
THE ZUKE
Hello friends,  ;)
If you have problems with the old seal of the water pump (for example).
I used this product: LOCTITE 7200, it's just magic  :perfect10:.
10 minutes of installation and everything comes off alone  :bravo: but be careful to protect the painted parts.
Then put the new water pump EDELBROCK but ... I have not yet received the panhead screws  :dunno: that replace those who rubbed on the back of the pulley
Did you get or make thinner bolts so the bolt heads do not contact the pulley ?
THE ZUKE
Quote from: Chryco Psycho on March 16, 2019, 09:49:18 PM
I ordered special screws 3/8-16 UNC 7/8"  ;), they will come from Germany.
They will be the same dimensions as those installed but with a different head
THE ZUKE
#40
It's good, the screws delivered.  :bigthumb:
Last night I went all up with teflon tape and sealing for nets.  :tool:
Everything goes great, no more need washers for the pulley does not rub.
Friday it will be the filling of the cooling system  :) and test .... ::)
Strawdawg
Might regret using red loctite if you ever have to pull it apart :)
Steve
Strawdawg
Steve
Looks great! Hopefully no more troubles for awhile!  :bradsthumb:
