Advice for fresh 440 .030
Started by Mopar94, August 18, 2023, 05:16:47 AM
Mopar94
OK Thank you for your answers !
Interesting article about LSA
My first choice was Whiplash. But 107° LSA.....
I'm really wondering if I'm going to take the summit one. This makes it much easier for me to pay shipping costs to France.
It will probably cost you 50HP & you will be disappointed  :rubeyes:
Mopar94
#17
Quote from: Chryco Psycho on August 28, 2023, 06:57:49 PM
Really ?
Ok Chryco. I'll call lunati. never mind the shipping and customs charges  :takemymoney:
let's go for lunati with custom grind 112 LSA
I hesitate between the 703 or the 704 (voodoo of course) :thinking:    with stock rocker, HP manifold,  2355 pistons and hughes 2400 stall torque converter  :bradsthumb:
Mopar94
Hello guys !
The voodoo 703 it's in production.
on the Lunati website it says : Makes un-equaled power to 6200 RPM with proper valve springs
I managed to find 2 spring references in their catalog
73100-16 and "upgrade" : 74820-16 ( BEEHIVE )
this means I need the second part number for the 6200RPM ?
It's OK for stock rocker ?
About connecting rods and pistons, I've changed my mind and bought a set of platinum pistons and forged 440-source connecting rods.
I would use the second spring [beehive] they are far more stable .
generally 6000 rpm is ok on stack rockers , if they are not badly worn , , I would recommend bronze bushed stainless rockers as an upgrade if you decide to to that .
Mopar94
My rockers is ok.
Ok for the beehive thanks Chryco
The seat pressure is more important than the first spring, it's ok for break in the cam ?
Break in is always a crap shoot , use good oil , start it one time if possible & le it run at 2k for 20 mins , don't rev it up
Mopar94
Ok Chryco
With the stock rockers, will I lose a lot of lift?
The stock rockers are not as accurate in the 1.5 ratio as other rockers "should be"
For street use I do not use alum or rockers with roller brgs on the rocker shaft , I only use rockers that are bronze bushed on the rocker shaft as this give a far greater surface area & lean towards Stainless steel roller tip rockers for durability .
When using any aftermarket rocker DO NOT overtorque the rocker shaft to the head , if the shaft becomes oval the rocker can seize holding a valve open which can break the piston & cause the whole engine to end up as Junk [ the intake should survive!] I have seen this in person .
Mopar94
Hello, update for my 440
It's run very well with your advices !
all went well during the break in !
the longest 30 minutes of my life
I finished the engine at the end of September
1200mi since september.  :D
:burnout:
