avatar_CudaHead
Best water pump for a Cuda 340 driven on the street?
Started by CudaHead, May 13, 2018, 05:27:48 PM
Quote from: CudaHead on May 14, 2018, 02:09:34 PM
Thanks for the reply. You did not mention where you get those.
This one came from Classic Industries. But other vendors may be able to get it. I only used them because I needed it fast and they were the only ones who had it in stock.
Quote from: CudaHead on May 14, 2018, 09:57:49 AM
And that's the way it should work. I have a 318 with a/c and it never gets close to overheating.
I ordered the correct 7 blade fan and clutch this morning from Tony's.
I'm trying to get the guy at Glen-Ray to have them build me a max-cool correct radiator but he is on vacation in Hawaii. That might take a while.
In the mean time, I also ordered a carburetor heat isolator to make sure the fuel does not boil when it heat soaks. It did when I stopped.
I also found the radiator cap was junk. I put a correct one on I got from Classic Industries.
If I still have problems, I will change the water pump and put air flow seals on the hood.
I will fix this.
FWIW. 318s have a much smaller bore 3.910 vs 4.04 (if memory is correct) 318s generate much less heat. Original I had 318. I could run or idle it all day long in 100 deg. Never would get hot. Believe 19in rad. Dropped in a 360 (4.00 bore). All other items remained the same. It would steadily climb to over heat. Moving or not.
Good luck.
