avatar_FSHTAIL
BS23 Cuda 340, large radiator, all SBM hoses fit?
Started by FSHTAIL, May 21, 2018, 11:12:36 PM
FSHTAIL
I'm looking around on Rockauto.com to replace all radiator hoses, bypass, ect and see no mention of the larger style radiator in terms of hose fitment.
Are all hoses the same?       I have the larger 26"  or 28"? (I believe that's the size)
It's definitely the larger radiator..      I just figured I'd touch base with the collective to avoid the wrong stuff..
FSHTAIL
I'm guessing the hoses wouldn't be too far off since its only a few inches off?
Look it up as with A/C... All A/C cars had the 26" radiator.... Then again I think all 340 cars had the big radiator too....Which is odd cause 383/440 & 440-6 all came std with a 22" if no gear package or 4spd....
FSHTAIL
Quote from: 1 Wild R/T on May 22, 2018, 10:35:44 AM
I didn't know that.
Thanks Wild.
I used to live by Home Depot btw.
Carpenter Briggsmore area
340challconvert
I picked up my small block 340 radiator hoses from Jacks Mopar Parts
Good selection of correct applications
HO-9878    UPPER  70-74 A Body (340/360), 70-74 B Body (318/340), 74 B Body (360) &  70-74 E Body (318/340/360)    26" radiator     $ 39.95
HO-9430  LOWER  70-74 B & E Body (All SB)  (no Mopar logo)  $ 34.95
They also carry the water bypass hose
https://www.jimsautoparts.com/belts.htm
:wrenching:
FSHTAIL
Quote from: 340challconvert on May 23, 2018, 04:59:03 AM
:wrenching:
Rockauto...     Continental brand hoses..
I have a driver car.
Quote from: Chris Pauluk on May 22, 2018, 10:39:08 AM
I didn't know that.
Thanks Wild.
I can understand leaving..... Just not sure I could understand Minnisnowda...  And the company I work for is based in St Paul.... They have asked... I haven't accepted....  Momma ain't leaving her grandkids anyway....
