Harmonic balancer suggestion for a 340 steel crank motor
Started by soccernut43, August 15, 2020, 07:36:39 AM
soccernut43
Any suggestions for a harmonic balancer for a steel cranked 340?  Motor used to be balanced internally for racing purposes but putting it back on the street as a cruiser.  Just reusing internals like pistons, rods, and steel crank.  Thanks in advance.
I know there are steel balancers available aftermarket , Pioneer or Proform some are SFI spec & generally around $100
soccernut43
I saw some of those but then learned that cast crank harmonic balancers are different then steel crank balancers.  And with the engine no longer being raced and internally balanced I can't use the old balancer.  So that opened up a whole other can of worms for me as to which one was best for my application.  Thank goodness for this forum lol.
Getting a balancer for an internally balanced engine is far easier then trying to get one for external balanced engines .
autoxcuda
Quote from: soccernut43 on August 15, 2020, 08:14:42 AM
Did it get rebuilt with different rotating assembly?  The balance job needs to happen before you assemble the internals
What does not being raced have to do with the balance of the rotating assembly?
Spring Fling 37, May 3 &4, 2025 Woodley Park, Van Nuys CA, 500+ Mopars, 200+ all Mopar swap, Malibu Cruise, Mopar Cruise-In: www.cpwclub.com
soccernut43
All the same components from 36 years ago as far as pistons, crank, and connecting rods.  Changed the rod bolts to ARP bolts and had the rods trued up.  I didn't have it balanced as I was just going to put it back on the street.  Not sure I can trust the balanced harmonic balancer.  Was going to play it safe and get an externally balanced balancer or one that was similar to stock.  Guy that did the machining agreed.
If it is a steel crank 340 it should use a neutral balance damper not external
Fastmark
I think you are over thinking this. A 340 is either internally balanced or externally balanced. All steel cranks are balanced internally so the balancer will be just neutral balancer. If you feel like you need to change the balancer for some reason, just get another neutral balancer and be done with it.
soccernut43
I probably am over thinking it but I can't help thinking the original balancer was matched to the original rotating assembly. Now that rod bolts have been replaced I can't help think that the rotating assembly won't match the balancer now.
soccernut43
Even if the rotating assembly changed rotating weight wise?
Quote from: soccernut43 on August 16, 2020, 04:36:50 PM
If, as you've mentioned several times, it's a street car, the minute difference in weight between oem and arp rod bolts is the least of your worries. An external balancer has a pretty good sized weight offset and putting one on your internally balanced setup would not make you or the engine happy. In the spirit of the K.I.S.S. principle, get a stock steel crank a/m or oem balancer and have done with it. As always, just my  :alan2cents:
JonH
Quote from: jimynick on August 16, 2020, 06:37:45 PM
x2....what he said
soccernut43
Think you've solved it for me.  I'm going to use the balancer that was used when the engine was originally balanced. The only thing that changed from that whole rotating assembly is the rod bolts and rings.
Thanks as always guys.
