Heat soak/vapor lock problem
Started by CudaJon, April 01, 2023, 01:06:30 PM
cnm2215
Quote from: CudaJon on April 04, 2023, 05:02:07 PMGreat feedback - thank you all. Will report back with my findings hopefully I'll get to play car this weekend. Thanks again!! :worship:
Hey CudaJon!
Did you end up getting this resolved? My 73 Cuda 340 has the exact same problem (though mine does not have the original gas tank, does have the charcoal canister, and has an Edelbrock AVS2 carb).
torredcuda
Quote from: Xghobo on April 05, 2023, 05:02:36 PMA friend went through this and tried all the things mentioned here. It ended up being the fuel pump rod
Go figure
Not saying vapor lock doesn`t happen but I`ve seen many times what someone thinks is vapor lock turns out to be a different issue.
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
