How to make the exhaust smell less??
Started by Fern, December 13, 2018, 03:19:55 PM
js27
I have the same problem. Doesn't smell rich or smoke but go for a cruise top up or top down it doesn't matter my clothes stink. I never had that problem with any other Mopar I had. It is a 440 with a Lunati 507 cam -Holly 750 DP-MSD Pro Billet Dist with coil and 6A Box. I am not a great tuner but will look into some the suggestion here. Please let me know if you fix the problem-in the mean time my wife will keep busy washing my clothes-LOL.
JS27
Fern
Quote from: Cudajason on December 14, 2018, 07:04:19 AM
Do you have your vacuum advance hooked up???
I do have the vacuum advance hooked up.
Unfortunately there's not a dyno shop near by to tune it properly.
The holley 770 avenger only gives instructions to tune by best vacuum at idel. There's only 2 adjustmet screws.
O2 sensor sounds like a good idea, was trying to keep costs down since I would like to do a modern hemi swap some day.
Cudakiller70
What do your spark plugs look like? Both a lean and rich condition can have a gas smell.
Try setting your timing by the vacuum method? I haven't done this yet, but sounds like it's worth a try.
Quote from: jimynick on December 13, 2018, 07:55:28 PM
The smart ass in me wants to say "then just don't drive it so much" Sorry  :crazytalk:
Or just drive faster, all windows down.   :haha:
JS
If that is an MSD Blaster 2 coil you don't want to mount it horizontally on the intake. They are meant to be mounted vertically and eventually fail on you that way.
Anyway, I have an LM-2 AFR o2 setup on my christmas wish list  - cannot wait!!  :banana:
Cudakiller70
Good catch on the coil, maybe spark has been degraded?
Possible. Easy to change out and see but pulling the plugs will also tell you how rich its running.
Fern
Quote from: HP_Cuda on December 14, 2018, 10:05:53 PM
JS
I have a flame thrower coil with 4 seconds flat hrr688 ignition.
Will pull plugs next.
