avatar_cuda hunter
Industrial 440 Information Please
Started by cuda hunter, December 12, 2021, 09:19:05 AM
cuda hunter
So as to not dilute @Shoooter  thread here, https://forum.e-bodies.org/engine-transmission-and-rear-end/4/engine-and-rear-ends-out-of-trucks-whats-the-difference/23759/ I thought I would go ahead and start another thread.
  I'm not familiar with the industrial motors.  I have a friend who has rebuilt hundreds of 440's and 413's all industrial irrigation motors.
  I find that some of the 440's and 413's have  6 bolt and 8 bolt cranks.
As @YYZ pointed out, @cuda hunter - you are right, the blocks can certainly be used without issue
Some cranks can be used in car applications, others not.
The 2 things to watch out for are:
1.  No centering ring on the crank snout for the flywheel or flexplate
2.  The crank itself may be longer than a passenger car crank and if so, it won't be possible to use the normal clutches or torque converters.
Some of the heads are a bit wacky as well, but I don't know the finer points as to why they can't or shouldn't be used.
cuda hunter
I'm hoping to get as much information about the industrial motors as possible.
I have many of these available to me.  Not that I need them or anything, but I see them quite often in farm country.
Actually I have a rebuilt 413 sitting in a shed that my buddy keeps trying to get me to put into a car.
Here are some pictures.
Most vin pads are blank.  One industrial motor has a stamp on the vin pad.  Non of the others I have found do.
These first pictures are of a 413 that has been converted to use 440 heads.
cuda hunter
 :rebelflag"
cuda hunter
 :rebelflag"
cuda hunter
 :rebelflag"
cuda hunter
 :rebelflag"
