Need help adjusting timing. Whiplash cam
Started by Fern, May 16, 2020, 01:43:40 PM
You are very welcome !! :bradsthumb:
You might almost think I had done this before LOL  :thinking:
71383bee
That's good to here.
I'm curious to hear opinions regarding this cam.  Please post your thoughts later after you've had some time with it.
72 Challenger
@Chryco Psycho Just a question for my own knowledge:
Why does opening up the plug gap help? When should you know to do this? I am not to experienced with engine building but have always kept the factory spark plug specs.
Someday I will have a J0b.
Any coil will only create the minimum power to jump the gap so increasing the gap makes a hotter / higher power spark + it will increase exposure of the spark to the fuel , anytime you have difficulty getting fuel to burn , high compression , poor fuel mix due to long duration cams etc it will help to create the burn vs dumping unburnt fuel into the exhaust  . You do need to make sure you have a high output coil that is up to the task of continually building higher enough voltage to create the hotter spark .
72 Challenger
