avatar_7212Mopar
Negative Supercharging
Started by 7212Mopar, August 21, 2017, 10:44:32 PM
I came across this website while checking out engine mounts. Still trying to read through the materials and to understand it. They make kits for Mopar. Anyone tried It? Crazy torque numbers but not very high in horsepower.
http://impulsengine.com/index.shtml
First time I've seen it.   :notsure:  So without reading all the site, how are they doing it?
Running smaller header, close exhaust valve sooner and run hotter charge. So far all contradicts with normal way of making power. Still reading.
cudabob496
Tunis
 :barf:
A lot of bullshit and contradictions in there. We all know that cylinder pressure is the key to performance. The higher, the better. We are now talking the difference between peak pressure at TDC compared to the back pressure in the exhaust. The dynamic compression of the engine will affect this, so will also the temperature (lower better) and pressure (higher better) of the premixed air and fuel mixture. Combustion in the cylinder will increase the temperature of the gases, which increases pressure as the volume is more or less constant, by roughly the same ratio irregardless of the starting conditions. This is why diesel engines makes more torque because of the higher static compression of the engines. Higher pressures also means denser gas, which helps combustion as the molecules are closer together in the volume they occupy.
Everything on that website contradicts this.
Sorry, didn't mean to lecture anyone, just tired of reading stuff that contradicts everything I know about thermo dynamics and combustion chemistry, that charlatans try to unload on people.
cudabob496
NPS is actually a real thing.  What the website fails to explain is that in order for it to work efficiently, you need to install one of those Tornado Gas Saver inserts.
Perhaps they utilize the new secret Mazda development ..... the OZONATOR    :dunno:
This reminded me of  the Smokey Yunick engine that got some hype some time back
http://www.hotrod.com/articles/ctrp-1004-pontiac-fiero-hot-air-engine/  :woohoo:
Actually Darren it only works if you change out your blinker fluid and chrome muffler bearings.
Quote from: Burdar on August 22, 2017, 01:56:12 PM
"Scotty,  bring the wrap drive online now."
"But captain, we are down to impulse power only."
cudabob496
Shields are failing! Commence Negative Supercharging on my mark!
cudabob496
