Power steering pump
Started by JCode, September 20, 2023, 06:49:54 PM
JCode
Does anyone know the part number for the power steering pump not the fast ration for the TA
  Would depend on year and model, specifics for many of these are available on the resources page
                            https://www.e-bodies.org/resources/
MOPAR MITCH
IF you truly want your ps pump to work well.. during fast steering action manuevers (LRLRLR...), then AVOID using the FEDERAL pumps... and ONLY use the SAGINAW pumps.   The FEDERAL pumps came with the T/A Fast Ratio (and typically any car with a 3.55 or numerically higher rear gear)... and those FEDERAL ps pumps will NOT keep up with the demand of fast action LRLRLR steering inputs, even worse as the rpms would increase upwards.   Best pump is a SAGINAW... then just be sure you get the correct matching hoses as the ends are different for the hi-pressure hose... box-to-pump.   You will also need specific brackets per style of ps pump.
IF factory original is your desire, then you may have to stay with a FEDERAL ps pump, BUT... your power assist steering performance will suffer with the FEDERAL ps pump... guarnteed.
