PS PUMP
Started by Cudajason, March 17, 2022, 09:01:16 AM
Hey folks,
I am in the process of installing a hydro boost set up in my cuda and instead of teeing the returns line together,  I want to add a second return line to the pump.  In short I want to drill a hole a the top and add a bulkhead fitting.
I have the style of pump pictured below, are these rare or year specific?
I was thinking the tear drop style (Later?) would be easier to add the fitting to, but, I don't have one of those.
Anyone know where I can pick one up cheaply, or do I just drill out the one I have?
The later style reservoirs are a dime a dozen.  I'd look for one of those.  Even when the pumps went metric, the reservoirs stayed the same.  You should be able to find one fairly easily.
RJChallenger
I have 2 of those pumps you can have both
Filthy Filbert
Curious, why do you not want to use a T on the low pressure return line?
Quote from: RJChallenger on March 17, 2022, 11:06:36 AM
Hey @RJChallenger Thats a very generous offer. Lets connect and make a deal, happy to pay you what they are worth.
Quote from: Filthy Filbert on March 17, 2022, 11:40:50 AM
@Filthy Filbert I have read that there is a possibility of feedback or a pulsation if you T the return lines.  So why not prevent the issue ahead of time.
Personally I would just use a Y fitting so the return has a direction towards the pump .
Quote from: Chryco Psycho on March 24, 2022, 07:55:51 PM
Hey @Chryco Psycho , I guess it can not hurt to give that a try.  :notsure: Maybe a little less time involved and I do not need to pull the pump off.
Given the warm weather is quickly approaching,  I would like to get this done sooner rather them later.
