with a/c to no a/c
Started by 73TopBanana, June 26, 2019, 08:58:27 AM
AS I had pointed out without the picture
Crank & power steering are the second belt
Quote from: 73TopBanana on June 26, 2019, 12:36:41 PM
ANLAUTO, those are just what i as looking for. i thought the power steering belt went over the upper pulley not the bottom one.
Thanks and have a good rest of day  :unitedstates: :canada:
You're welcome.....like they say....."a picture is worth a thousand words"  :worship:
70 Challenger Lover
The two pipes coming out of the firewall are for the evaporator. I would cap them simply to keep dirt and grime out. Takes very little effort and if you or a new owner ever decide to add the AC components, it will make for less work.
73TopBanana
hello all, removed the ac components, can i remove this hose assembly and just run new straight hoses?
73TopBanana
good morning,
ok so these photos show the pulleys after removing the ac components. do i have to install a new crank pulley for the power steering belt?
Next question, forgot to tag the alternator wires, which brown clip attaches to the alternator?
thanks all
sorry am struggling on how to post pictures
Quote from: 73TopBanana on June 28, 2019, 07:10:35 AM
Yes but you'll likely get continuous hot air it the car with no way the control it.
In my opinion, like I suggested. You should buy two new pulleys and alternator brackets and set it up like in the photos I posted earlier .
73TopBanana
Thanks, always appreciated
73TopBanana
Yes, have the brackets, will get the 2 pulleys.
which of those 2 brown plugs go to alternator?
thanks and have a good day
With the existing belts and pulleys you might be able to make something work with what you have. It looks like the fan lines up to the PS pump, maybe you could run those two together off of the crank, then run the alternator off just the crank ???? :dunno:
Personally I would get the proper stuff.
The alternator should have one large power wire and one green wire and one blue wire plugged on the back
73TopBanana
yes, agree, will get the proper stuff and keep the old in case want to go back to AC.
Could you tell me what the single brown plug and the double ground plug are for?
unfortunately i did not label them.
thanks
None of that wiring looks factory to me...so I'm lost...I don't play with 73's all that much ..Sorry :clueless:
73TopBanana
73_Cuda_4_Me
I have a brown wire in alternator loom, but it goes to the windshield washer pump plug by the charcoal canister...
I do not have a double-black wire connector... was that possibly for the AC compressor? Mine did not have AC...
Like Alan said, should be one larger wire (black, according to schematic) going to the B ring terminal on alternator, and a blue wire and a green wire going to the two spade Field terminals on the alternator.
Best way to find out is trace them back to firewall connector pin origin... or wherever they come from...
If you don't have service manual, this may help.... http://www.mymopar.com/72to76_wiring.htm  Refer to schematic A for engine bay wiring...
BS23H3B
73TopBanana
Thanks for the help, much appreciated, that makes sense, took off the washer pump awhile ago and the AC unit.
