with a/c to no a/c
Started by 73TopBanana, June 26, 2019, 08:58:27 AM
73_Cuda_4_Me
You don't happen to have fender turn signal marker lights, do you? There are double-black connectors for right side fender turn signal marker...
BS23H3B
73TopBanana
If you mean the turn lights on top of fender near hood, do not have those, hopefully will add some day they look great on these vehicles
73_Cuda_4_Me
I would try tracing the black wire(s) back to firewall connector and whatever else goes to...
BS23H3B
73TopBanana
73_Cuda_4_Me
Just payin' it forward, like so many others that have helped here along the way...
:handshake:
BS23H3B
I did not get new pulleys. I'm not at home now to look but my set up is opposite what Alan posted although I expect his picture is the more original/correct way. Use the pulleys you have and get belts that are the right length to make it work.
73TopBanana
blown motor, when you get a chance can you send me pics of your set-up?
You Canadians are awesome. Wish more people around here were like you.
:unitedstates: :canada:
I'll do it Monday. I'm in Rochester until then. I have fan, power steering , crank on one belt and alternator, crank on the other.
@73TopBanana I found pics on my phone.
73_Cuda_4_Me
@blown motor - Is that a 3-groove crank pulley???
BS23H3B
73TopBanana
Thanks for the pics. I see How you did it. Looks good.
73TopBanana
hello, if the existing valve set up is left on will i still get hot air?
Similar idea as Blownmotor but on a BB . I ran them this way thinking if I ever lost a belt I could still keep driving as the water pump is always turning no matter which belt goes. I have no idea why Mopar didn't run them this way?
73TopBanana
thanks, have a good day  :unitedstates: :canada:
