avatar_blown motor
Anyone with El Camino knowledge?
Started by blown motor, November 01, 2018, 12:18:27 PM
A friend is doing up a 59 El Camino. When he pulled the box floor, instead of finding the frame there was a sub floor plus this large cavity at the front of the box. What is it for?
1Burgfish
 :wrenching: Those 59 Elkies are cool looking especially the sideways fins; not sure were that part is located? is it inside or out back?
@1Burgfish It's at the front of the box right behind the cab. You can't see it unless you remove the box floor and there is no access panel.
I think he should foam the walls, add ice and beer.
318Stroker
From a quick Google search:
1959-el-Camino When it was introduced, the 1959 El Camino was a conglomeration of several GM cars. The car was based on the Brookwood 2-door wagon, the exterior trim was that of a Bel Air, and the interior was borrowed from the Biscayne. The El Camino was also billed as the first Chevrolet pickup to have a steel bed floor rather than wood. Interestingly, the steel bed floor could be removed, revealing the rear portion of the Brookwood floor pan, foot wells included.
Yep ,cool feature, google " el camino smugglers box "  :D
Quote from: 318Stroker on November 01, 2018, 02:18:56 PM
And now you know....the rest of the story.
Thanks 318Stroker
PlumCrazyRTSE
Those El Caminos are like catnip to the ladies!
https://www.youtube.com/watch?v=inRkIiwqPhc
....sorry, I just couldn't resist.  That was the best line ever from Stargate SG-1.
1Burgfish
 :wrenching: It might be a rear seat that folds down; because I remember the Chevy Townsman models which were like the Brookwood and they had fold down rear seats that you would pull up by a strap. They did this on the station wagons so you could carry paneling, 2x4's, sheetrock from the Hardware stores. Dual purpose vehicle if you had a family.
Yes, a continuation of the more door floorplan.
Early Rancheros had a similar setup.
