avatar_nsmall
Hood release location?
Started by nsmall, February 19, 2018, 04:11:15 PM
nsmall
So my hood release has a curve to it yet I don't see exact location of where to mount it.
Does it mount to the area were there holes underneath the left side of the dash frame?
Thanks in advance
Neil
That's not a factory E Body part, so you're just going to have to make it fit somewhere  :alan2cents:
nsmall
Thanks Alan.  Kind of the theme of this build.   :bye:
So it should mount somewhere on the dash frame?  Like as far to the right as I can get it?
THANKS
CudaMoparRay
[quote So it should mount somewhere on the dash frame?  Like as far to the right as I can get it?
[/quote]
Did you do this yet?
I'm thinking of doing something similar when installing my inside cabin hood release upgrade on mine.
Usually tucked in pretty tight to the kick panel...
I would mount it using one of the factory dash holes as far Left as possible without interfering with the park brake
nsmall
Quote from: Chryco Psycho on February 25, 2018, 05:26:57 PM
Thats what I did.  Hood opens fine and I can get to the ebrake so time to move on to the 101 other items on the list.  Thanks
@CudaMoparRay   If you want a pic I will post some.
tman
Id like to upgrade mine too. Have pics of routing from interior to  latch? Thanks
CudaMoparRay
@nsmall If you could post some pics would be great. Thanks
Quote from: anlauto on February 19, 2018, 05:02:40 PM
You sure about that? Looks identical to the one in my '73.
nsmall
@tman @dodj @CudaMoparRay @Burdar
This is my first build so don't go by my pictures but this is what I came up with...
tman
I found this link when looking for a picture of the correct location.(my car doesn't have a cable)
https://www.forebodiesonly.com/forum/threads/remote-hood-latch-cable.12201/
CudaMoparRay
Quote from: tman on February 27, 2018, 01:35:39 AM
Thanks for the follow up
:iagree: Yes, thanks for the pics, gives us a good indication on what to do.
nsmall
@CudaMoparRay @tman
Check out the link Burdar sent....https://www.forebodiesonly.com/forum/threads/remote-hood-latch-cable.12201/
This makes more sense and I will post pics once I remount the actual handle as it looks like it will fit in the area the guy on forebodies posted in the link above.
