avatar_CudaMoparRay
340 motor exhaust manifolds
Started by CudaMoparRay, December 09, 2019, 03:18:36 PM
CudaMoparRay
Removed from my 1972 Plymouth 'Cuda 340 motor exhaust manifolds in excellent condition.
May fit others, please check pictures for appropriateness.
WIW? Thanks
1972V21Cuda
Date codes indicate a later model (not a 1972). In addition, the driver side manifold is incorrect for 1971 - 1973 'Cudas.
CudaMoparRay
Quote from: 1972V21Cuda on December 09, 2019, 04:20:42 PM
Originally I was thinking of taking the headers off and replacing the "original manifolds" but according to your information it might be best to just leave the headers on as the manifolds may not be from this engine after all  :notsure:
ply64post
If I had a good picture of the left side casting number I could tell you what it is off of. The right side is 3418623 and will work on 71-73 A B E body 340 or 71-73 c body 360. The left side looks like a A or E body because of the way the neck is curved to go around the steering.
                                                               Hope this will Help
        Jeff
I think the driver's side is A Body as well :alan2cents:
CudaMoparRay
Quote from: ply64post on December 10, 2019, 01:21:53 PM
                                                               Hope this will Help
        Jeff
Better pictures but not sure if 40067.1.N not sure if 3 or 8 and O or D then N
ply64post
Ray
Sorry for late reply.
I am not sure why the left manifold has only 5 digits, there should be 7 digits for the casting #. The casting # for your left side starts with 40967-- making it a later casting. Dates on the casting I can't read.These parts and casting #'s were gathered from the original parts books.
Part #2863545  Casting # 2863549  RH 68-70 A E 340
Part #2863552  Casting # 2863553  LH  68-71 A 340
Part #2863552  Casting # 2863553  LH  70 E 340
Part #3418624  Casting # 3418623  RH 71-73 A B E 340
Part #3418624  Casting # 3418623  RH 71-73  C  360
Part #3418620  Casting # 3418621  LH  71-72 B E  340
Part #3418620  Casting # 3418621  LH  71  C  360
Part #3614367  Casting # 3414368  LH  72-74  A  340-360
Part #3751083  Casting #   N/A        LH  73-74 B C E  340-360
Part #3751393  Casting #   N/A        RH  73-74 B C E  360
CudaMoparRay
Quote from: ply64post on December 22, 2019, 07:58:45 PM
Ray
Well it looks like, at least for the driver side, I have a real mystery that has stumped the experts  :thinking: :notsure:
Sincere thank you to @ply64post , @1972V21Cuda and @anlauto for the good old college try  :banana:
