drum brakes work until vacumn is connected to booster
Started by culp71, June 27, 2018, 08:00:49 AM
culp71
so 70 cuda with drum brakes all around, has booster. (bendix style booster, I believe) brakes function perfectly until vacuum is connected from manifold, and or carb. then pedal has no resistance, goes to floor and drums rotate freely...plus a little fluid was forced out of the master cap....thoughts?
bad valve in booster? everything is new.
I removed the line, left fitting on booster open, worked fine. I put a cap on it, also worked fine.
I tried two different vacuum sources, but both cause this "no brake" issue.
That's a weird one. Vacuum should have nothing to do with loosing the pedal. I wonder if you have the correct master cyl for power brakes. Do you have the correct rod in the booster?
Joe
xx88man
Quote from: Brads70 on June 27, 2018, 02:42:47 PM
power drum brakes? That's a new one on me?  :notsure:
:iagree:  Never heard of a booster with drum brakes before
Keep yer foot in it
Yikes...what's the fender tag/broadcast sheet code for power drum brakes ? Certainly an odd duck :huh:
6bblgt
searching for an answer, stumbled across this thread @JH27N0B do you (or anyone) know what the correct casting # is for the master cylinder on a Power Drum Brake '70 R/T w/11" drums?
what's the correct finish for: lid - hold down bracket - bolt?
is this the same BENDIX booster as the "TRANS AM" cars?
to answer a couple above questions - power brakes is power brakes - nothing different on a fender tag = B51
1970 Challenger R/T hardtop JS23 (shipped US):
STANDARD manual drum brakes B11 ~54.7% installation rate (~7,476 cars)
OPTIONAL power drum brakes B11 & B51 ~ 10.9% installation rate (~1,490 cars)
OPTIONAL power disc brakes B41 & B51 ~34.4% installation rate (~4,702 cars)
Wow...what an odd option to have  :huh: Learn something new everyday, thanks Dan :drinkingbud:
Thanks ( again) for the education 6bblgt !  :clapping:
@culp71  what did you find was the issue?  Bad master or booster? or...? The education continues!  :D
