avatar_anlauto
E Brake Cables and Frame Connectors-RESULT
Started by anlauto, October 20, 2017, 02:25:54 PM
Okay....How did you guys deal with this ? Pictures ?
@RUNCHARGER that FJ5 car had frame connectors, what did you do ?
Solid frame connectors that are welded to the floor have to have an "access" route for the cable.  If you do the ones that have a gap then the cable should be able to run above it.
I drilled the drain holes after they were welded in and about took my arm off when the drill would catch.  Drill them first on a drill press before you weld them on.  You can make the frame connectors look very stock.
Okay, thank Cody, yours look amazing.....
However it's a little too late for the car I'm working on....The frame connectors are there with no provisions for the E Brake cable and they cover-up the pass through holes for both the fuel line and brake line at the transmission crossmember... :steamingmad: :'(
I did the same thing as Cody, slit a tube and welded it in before the connectors were welded in. Sorry no pictures....
Wonder if I could drill/cut two ovals and get a tube in there now ?
Might have to drill some holes to get it to work.  You can touch of the paint after and it will be fine.  I would rather have an E-Brake then perfect paint on the bottom of my car.   :alan2cents:
No issue there, the car is NOT painted yet.... :twothumbsup:
BFM_Cuda
I mapped out my cables like Cody did, (mines a 71') and then drilled holes to let the driver side cable and passenger side hook to go through. I plan to add a rubber grommet to the holes so the cable wont rub or make noise if it vibrates on it. I am expecting I may have to lengthen or shorten the middle cable, depending on how it sits once its all in place.
Quote from: Roadman on October 20, 2017, 03:45:33 PM
Why not eliminate the pedal assembly and cables.    https://www.summitracing.com/parts/esc-esk001/overview/
How does Toxic like them after having used them for a while?
Roadman
Quote from: dodj on October 20, 2017, 04:14:32 PM
                   Last we talked, all good. But lets see if we can get him off his but to chime in @ToxicWolf .
Quote from: anlauto on October 20, 2017, 02:41:53 PM
If it's already welded in the car I don't see how your going to weld it in, just the sides would be accessible. If you don't weld it all around it weakens the connector and kinda defeats the purpose?
If your think  of welding in a complete round tube  by drilling in 2 holes from the sides I'm not sure if that would work? I can't remember how big the end you need to fish through is?   For what it cost in material not a big job for your metal guy to cut it off and make new ones. Drilling and Welding tubing in significantly makes it stronger with little weight gain....... :alan2cents:
I was late to the party too and it wasn't that great. I was going to drill holes but I ended up taking a grinder and cutting slots into the dang things as I didn't want any chance of being off a fraction with a drill and having the cables rub. If I had done it from scratch I would have welded a brake tube in for the cable to run through.
If I was doing that car again I would have cut the suckers out and primed the belly the way it should have been done to start with.
Quote from: RUNCHARGER on October 20, 2017, 05:33:37 PM
Two slots would be the simple way to go I guess.....I'm all for taking the ugly things out, but I doubt the owner would be crazy about that idea... :pullinghair:
