Heim Joints
Started by dodj, July 25, 2023, 06:10:29 PM
This morning the DW and I went for a cruise...and the front end groaned and creaked an embarrassing amount. After we got home I jounced the car and the noise was coming from the ps strut rod heim joint.
I opted to not buy Hotchkis control arms because of the reported issues with heim joints.
However, a few years ago, ignoring what I knew about heim joints...... I bought adjustable strut rods with heim joints. Bad decision I guess.
So...how do you quiet down a heim joint? It's not loose or worn. Probably no more than 4 or 5K miles on them. I sprayed penetrating oil on it and it's fine at the moment....but I'm sure it is only a short term fix.
Do I toss these strut rods in the bin or is there some maintenance for these joints I'm unaware of?
:huh:
Pack Marine grease into them not spray oils .
Quote from: Chryco Psycho on July 25, 2023, 07:17:23 PM
How? Nowhere to put the grease
70rag383
I had exactly the same problem with my aftermarket upper control arms. I first spray the joint with WD-40 to clean it and then spray again with silicone grease. I do this annually when I put the car away for the winter. Works very well and is not messy at all.
BIGSHCLUNK
Never had an issue. Wish I could remember what brand mine are, too long ago since install  :notsure:
If you roll the center over 90* you can pack grease in there , but they have to be unbolted to do it .
Quote from: BIGSHCLUNK on July 26, 2023, 06:30:22 AM
We have the same ones Biggs.
Chryco, i unbolted them and moved them all around but didn't see how I could get any grease in there?
Quote from: 70rag383 on July 26, 2023, 06:27:13 AM
Well, I'll do this for the rest of the season. If they start to creak and groan again I'll look into those QA1 pieces and give them a try.
Thanks all  :bigthumb:
rikkitik
 If/when, mine ever become an issue,  I'll probably just order a set of hiems with zerks from McMaster.
https://www.mcmaster.com/products/hinges/ball-joint-rod-ends-with-grease-fitting-10/
Racer57
Quote from: dodj on July 26, 2023, 08:01:49 PM
Remove the heim. Rotate it one direction and smear grease on the ball. Then rotate it the opposite direction and smear grease on the ball again. Keep working it around smearing the grease and it will get covered.
