Line Lock Recommendations
Started by RayL, March 11, 2024, 07:31:56 PM
RayL
1973 Challenger 383 4-speed
I'm in the process of upgrading my braking system the Hydro-boost (link below) and wanted to include a line lock while I'm at it.
What type of line locks are best?
Is yours installed after the combination valve or between the MS and the combination valve?
Did you install a safety switch to prevent unplanned line lock actuations?
Where did you install the line lock switch (aka smoke button)?
Thanks everyone!
Link to the Hydro-boost thread: https://forum.e-bodies.org/wheels-tires-brakes-suspension-and-steering/12/hydro-brake-conversion-kit-experiences/30168/
mopar jack
I installed a TCI roll stop kit back in 1996 when I was racing in street class. The solenoid is installed between the master cylinder and combination valve. It's activated by a momentary switch mounted in the console.
RayL
avatar_mopar jack - Did the TCI unit have 2 outlets or did you need to put a Tee inline?
mopar jack
valve has 1 inlet and 1 outlet. No tee required since it's the supply line to the combination valve before it splits to each front brake.
torredcuda
Hurst Roll Control, I made a bracket that uses the master cylinder bolts and put in a tee.
Jeff   `72 Barracuda 340/4spd
Northeast Mighty Mopar Club
RayL
Quote from: torredcuda on March 13, 2024, 06:05:05 AMHurst Roll Control, I made a bracket that uses the master cylinder bolts and put in a tee.
Thanks avatar_torredcuda. I've seen several installations now. Some installed the solenoid between the Master and Comb valve. Some after the combo valve. I'll make that decision once I see how the hydro-boost setup goes together with the new combo valve (mine is rusted shut).
I'm leaning towards a kit with 2 outlets because 2 outlets provide flexibility for the install.
RayL
Update: I purchased these items but have not installed them yet. Still waiting for my Hydro Boost kit to arrive. I decided to add the stoplight pressure switch to the installation after reading a bunch of posts and the installation manual from Hurst. More to follow...
Hurst Launch Control, Roll Control with Stainless Valve Part # 1745000
https://shop.advanceautoparts.com/p/hurst/22904738-P
Master Power Brakes - HW2003 – Brake Light Pressure Switch
https://mpbrakes.com/product/hw2003-brake-light-pressure-switch/
