avatar_Mark_B
Wheel Spacers
Started by Mark_B, April 08, 2020, 08:41:23 AM
Mark_B
Hi All,
Does anyone use wheel spacers on their E Body?  If so what width do you use?  Are their any downsides to them?
Thanks for any help you can give.
BIGSHCLUNK
I prefer wheels with the proper back spacing.  :notsure:
I've put about 120,000 miles on wheel spacers from my Cuda, daily WRX and my old daily Wrangler.
Never a single problem and that Wrangler was ran HARD.
Cuda has a wheel shim on the rear with proper extended studs. WRX and Wrangler used bolt on spacers.
I have 25mm hub centric spacers on the front for probably about 5 years or so. No issues.
The ones I have are custom made by BORA. (Mike's recommendation actually  :bigthumb:)
If the wheels you want don't come in the correct backspacing for you, don't be afraid of using a quality spacer.  :alan2cents:
GrandpaKevin
I'm using 3/4" spacers from Summit Racing on the wife's Challenger to get the 15x10 wheel/ 325/50-15 tire combo centered correctly with the B body rear end.
https://www.summitracing.com/parts/AAF-ALL44122
Definitely needed longer wheel studs.
I check the torque on the lugnuts often and everything is working perfectly.
Headjam
You must really love your wife to keep checking the torque on the wheels.  :rofl:
