avatar_ec_co
1970 wiper motor options
Started by ec_co, March 04, 2024, 05:39:46 PM
ec_co
I looked and couldn't find anything, but I'm sure someone knows.
Will this '72+ design work for my '70 as an alternative? If so, do I still need to use the resistor from my '70? Keep or change the small wiring harness?
Any problems with these?
Thanks!
I can't tell you if it will fit a '70, but I can tell you it works well in my '73. Much better than the original that was there. You modify the harness to eliminate the resistor.  If I remember right you need to remove the wire from the four pin connector that comes from the resistor and replace it with the wire that feeds the resistor presently.
ec_co
Since it's a short harness, I wonder if using a '73+ short harness would work? I'm working on trying to restore my current one myself and not spending $400+ for a restored one. It's going to be a driver and not a show car so I just need them to work well. So I'm just looking for options in case I fail plus I'm having a hard time finding a replacement cam gear
I put a 72 motor in my 70, same harness.
The difference is the shaft size that connects to the linkage, slightly smaller on the newer motors.  I added a small shim to take up the slack, but don't think it's really needed.
ec_co
Quote from: Katfish on March 06, 2024, 07:49:14 AMI put a 72 motor in my 70, same harness.
Did you have to modify the harness?
No change to harness,
73 model PN 40-382
Quote from: ec_co on March 06, 2024, 07:53:06 AM
He wouldn't have to modify it because the original '72 motor still needs the resistor. The new one you are looking at does not require that external resistor.
Rebuilt motor doesn't come with that resistor, you'll need to reuse your old 1.
It attaches where that ground strap is.
I think the wiper motor is the only original type equipment I see in there Rod.   :bigthumb:
Kinda looks out of place.....
Horns are still there, although in the wrong spot..... Lol
The 5.7/518 combo has really been a joy, I've driven the car more this last year, than the previous 5 combined.
400hp and 20mpg, what's not to love  :banana:
Jay Bee
Must be an old picture, there's suppose to a 3 speed wiper motor there  :vipermanhiding:
Back to the OP's post, are Cardone motors identical to OEMs?
Quote from: Jay Bee on March 07, 2024, 01:48:40 PMBack to the OP's post, are Cardone motors identical to OEMs?
No. Not electrically. See post #1
Quote from: Jay Bee on March 07, 2024, 01:48:40 PMMust be an old picture, there's suppose to a 3 speed wiper motor there  :vipermanhiding:
The PN I used looks pretty close to original, don't think you could tell the difference.
If I can get my lazy mechanic to focus, plan is to eventually install a 3-spd wiper..........
EDIT
I guess it's actually rebuilt, so that answers that
Cardone 40-382 Remanufactured Domestic Wiper Motor https://a.co/d/hOro5rq
