Debugging the fuel gauge.
Started by Valkman, May 17, 2017, 03:49:15 PM
Valkman
Ok  my fuel gauge isn't working right,  and since the the filler neck seal was leaking l desided to pull the gas tank.  I pulled out the sending unit (which looks pretty new) and test the resistance.  It read about 67 ohms empty and about  9 ohms at the full level. The other gauges seem to be working properly so I think the dash voltage regulator is working good. I then hooked up the sending unit and dry tested it and here's what I found.
Set at empty the needle disappears.
When set at full the needle moves but seems to hit a mechanical stop right before the E.
Could mean the needle is in the wrong position?
@Valkman  is sounds like the fuel gauge is having some issue.  Not sure if this will help, but I made a quick video on how to check fuel gauges.  Good luck and let us know what you end up doingto fix it.
Valkman
Thanks Cody, I've seen that video, it was a great help, it got as far as I got to this point.
I don't want to have to pull the dash apart if I don't have to, but it looks I might be forced to.  If I do can anyone tell me how to inspect the gauge itself?
Before you take the dash out... Go to radio shack & pick up a few resistors....    Disconnect the wire from the sending unit & use a resistor between that wire & ground...  10 Ohms should register a full tank...  90 ohms should register an empty tank...
You should be getting a pulsing power signal through the sending unit lead with the key in the run position.... With an old analog gauge you should read about 5-6 volts... A digital gauge reads to quickly & you'll have a tough time getting a usable reading because the IVR pulses the power to lower it to the 5-6 volt range... 50% duty cycle = 50% of the full voltage...
Valkman
Quote from: 1 Wild R/T on May 17, 2017, 04:29:45 PM
Since I checked the resistance of the sending unit it's that doing the same thing?
When needle raises it comes a very hard stop you can actually see it bounce a little when it does like the travel is being mechanically limited
shawge
Is there a ground strap between the sending unit and the fuel line?
Colored wiring diagrams
Wheel spreadsheet
Valkman
Quote from: shawge on May 17, 2017, 05:11:49 PM
Yes, when I ran the test I made sure it had a good ground.  The needle moves so it's get a signal.
Sounds like the gauge is broke.  It should sweep smooth and not have any hiccups or get stuck.     :dunno:
Valkman
That's pretty much what I'm thinking.  One thing I did notice is that the gauge needle disappears  (see 1st photo ), when I was looking at replacement gauges the needle rest on E. Do you think it's possible the needle is out of position?
Maybe?   :huh:  It should be seen all the time and not disappear.    :alan2cents:
Quote from: Valkman on May 17, 2017, 06:18:20 PM
I agree, something is wrong with the gauge. It sounds like something has slipped out of place. The needle should not disappear and it shouldn't hit a stop in that position.
Quote from: RUNCHARGER on May 17, 2017, 06:42:30 PM
Agreed... But the sender is out of proper range too...  67 Ohms means when your out of fuel the gauge will be reading close to 1/2 tank...
shawge
Aren't the Mopar gauges calibrated for 70 - 10 ohm?
Wheel spreadsheet
Quote from: shawge on May 17, 2017, 08:53:58 PM
Actually 73-10........  I was thinking of Ford which is 90-10....  Sorry old & simply wrong...
Yes, there is a ground strap from the sending unit to the body fuel line.
