avatar_Mopsquad
Diagnosing charging system health '70 Barracuda EFI
Started by Mopsquad, June 14, 2019, 11:12:35 AM
Mopsquad
Quote from: crackedback on June 15, 2019, 02:04:56 PM
I'm not far from you over in Indio.
I build the 6 and 8ga charge wires with a fusible link.  Try to make them stealthy as well.   Simple to install.  I may have an ad up here somewhere.
Where are you tapping the system for your EFI?    Battery or starter relay on our mopars is a horrible spot with the factory charging system.
Let me know if I can help.
Thank you. I will certainly contact and inquire.
The EFI and MSD battery source are tapped at the junction pictured.
Mopsquad
Quote from: Chryco Psycho on June 15, 2019, 01:40:25 PM
The large stud on the Alt  with the 1/2" nut & the start relay , 1 wire from the positive battery terminal bolts to the relay
Is this the stud on the alternator that I tap into? Black plastic cover
See pic
crackedback
Mopsquad
Quote from: crackedback on June 15, 2019, 03:29:15 PM
That's the starter relay.
I used it as a junction block to limit the amount of wires direct to battery pole.
Quote from: Mopsquad on June 15, 2019, 03:07:59 PM
See pic
Yes that is correct alt stud. Notice how small the factory wire is... now picture that and only a blade terminal thru bulkhead.
Mopsquad
Quote from: YellowThumper on June 15, 2019, 04:00:01 PM
See pic
Thx. So I'll directly connect a 8ga wire from that pole to the battery.
crackedback
That wire MUST have circuit protection of some kind.
Yeah, people use the starter relay as a bus point and it's a horrible place to do it on our cars without the wire around set up.
73440
Mopsquad
Quote from: crackedback on June 15, 2019, 04:57:55 PM
I can use a separate junction pole outboard of the relay and use a 8 ga or so to connect to battery.
What amp fuseable link?
RCman
I'm also going with the stock alternator doesn't have enough gusto to keep up with the EFI / electronic ignition demands.
I ran into this exact same issue. I ended up grabbing some brackets from AR Engineering from Mancini Racing (Brad's post linked it) so I can run a Denso alternator for a 4cyl 2.4L 4Runner from 85-92 which has the same style v-belt pulley. 93-95 will also have a v-belt pulley but is a different plug end. Mancini has the plug and wiring for the 85-92 style. I now have no problem with 14.1+ V at idle. It is a slick setup and super easy to do, especially if you've already run the wire from the alt to the starter relay/battery (with protection of course).
Mopsquad
Quote from: RCman on June 15, 2019, 06:02:25 PM
Thx for the suggestion. I'm going to test the alt first.
My stock frame round back style alternator with upgraded diodes will push 85 amps so I see no need to put a Japanese alternator on my car....  I know the Denso's work great & I'm not saying thee's anything wrong with doing the change, I just prefer to keep my car "looking" stock...
73440
Example,
10 Ga. wire, 14 Ga. fusible link.
8 Ga. wire, 12 Ga. fusible link.
You have already proven there is more load than the alt can handle at idle so if you get caught in traffic you can run the battery dead & fairly quickly too as you have proven  , so My belief is you need to upgrade the alternator output to keep up with the load wether you modify the stock alt as Wild suggests or change to a high output one you will have to do it  , I have run into this a few times now with modern upgrades !
  You absolutely still need the bypass especially if the alt can produce more than 60 amps as the ammeter gauge cannot handle more than 60 amps & the connections through the bulkhead do not like 60 amps either .
Mopsquad
Quote from: Chryco Psycho on June 15, 2019, 08:05:46 PM
I can see a new alternator in my future. I'm curious about this bypass test with 8ga wire. Can I just temporarily connect the 8ga wire from alt stud to battery to test voltage?  I had to read up on what a fuseable link was - didn't know. For this test, can I not use a link?
