Dimmer switch coil spring
Started by RJChallenger, September 23, 2018, 04:54:39 PM
RJChallenger
I have a dimmer switch with a 2799 date code. The coil spring has popped out of the recessed groove . Has any body rebuilt a dimmer switch and if so what did you use to secure / glue the coil spring into position ? I really would like to keep the original dimmer switch that came with the car. thanks every one
I bought a new one from Rock Auto for less than $10; you could buy one and disassemble it and put on your case if that's the length you wish to go to. Just my  :alan2cents:
Quote from: jimynick on September 23, 2018, 05:18:46 PM
Didn't realize these are available new, got a PN?
RJChallenger
I'm not sending a dimmer switch to another country . I'm not buying a  switch from china. I just wanted to glue and test this switch and thought that maybe someone had done this before . I'll just try epoxy  and find out myself
I did not think the cap was glued on , I thought the cap had crimps on each side to keep it from popping off
I think he's referring to a dash dimmer, not the headlight dimmer....
One would expect epoxy to work for that.
RJChallenger
Yes it's the dash dimmer switch. I have four of them. Two more 69 and one 73 date code dimmers. As a millwright  I just don't buy things,I fix things. .To some of you people with more money than time, That's fine. I haven't worked in three years due to back problems. If I want / need parts for my car I have to trade / sell parts, to then be able to afford them . If I was able to fix this dimmer and have a  properly date coded factory switch in my 70 challenger, I then would have (two) like new dimmers to sell or trade. What makes this site "AWESOME" is the knowledge everyone is willing to share. Thanks
Quote from: 1 Wild R/T on September 23, 2018, 08:33:35 PM
That makes more sense...Jiminick sent my mind in the wrong direction with his $10 Rockauto part :drunk: :no:
Any light glue should work.  Epoxy is a permanent fix, not removing that in the future.
Quote from: anlauto on September 24, 2018, 05:10:33 AM
Yep, because Jimynick was under the apparently erroneous impression that the "dimmer" was the headlight dimmer- on the floor. Silly me, and if you can fix something, then I think that's a good way to go. Good luck  :cheers:
