avatar_Shoooter
Ignition kill switches or anti theft devices
Started by Shoooter, August 07, 2020, 12:08:57 PM
Quote from: Brads70 on August 08, 2020, 05:49:11 PM
Quote from: torredcuda on August 08, 2020, 04:58:41 PM
Quote from: Chryco Psycho on August 08, 2020, 09:56:31 AM
true but 3 bolts & the wheels is off
or a hack saw to cut the wheel
bolt cutter..... quicker I'd guess
Even easier, just unbolt the steering wheel like they did in the movie Gone in 60 Seconds when they stole it.
QuoteUse a hidden switch to ground the negative coil , hot wiring etc will have no effect , doesn't help much if they bring a tow truck tho
The tach wire hooks to the negative side of the coil right?  Sounds like it would be super easy to splice into the tach wire inside the car and run a hidden switch to ground.  Would that be bad for the tach though?  What about a Pertronix unit?  Any ill effects to that?
Exactly , the tach wire is already under dash , just splice into it & use a switch to ground it , at thyat point it cannot be started unless the tach wire is removed from the coil or the switch is located
Shoooter
Can you use the coil to a hidden switch with a standard dash with no tach?
Yes, but you won't have any existing tach wire to tap into.  You'll have to run a wire from the negative side of the coil to wherever you want the switch.
Quote from: Burdar on August 10, 2020, 07:18:44 AM
Really like this idea, where do we hide the toggle switch?
Quote from: Katfish on August 14, 2020, 06:59:07 AM
Anywhere semi convenient and hidden to toggle.
My first thought was converting the cigarette lighter. Push in ground. Pull out no ground.
I'm thinking if you feel the need to put such a switch in....I wouldn't say where I put it on the internet?  :dunno:
Quote from: dodj on August 14, 2020, 07:51:43 AM
Lol was my first thought as well.
But Google is our friend...
mopar jack
the cig lighter is a great idea everything seems to be 100% stock .
We did that back in the early 80s .
you can use a micro push switch about the size of a pin head , push on , push off .
I would never use anything a large & obvious a a toggle .
