avatar_FSHTAIL
Painted engine compartment, wipers don't work
Started by FSHTAIL, August 01, 2024, 01:37:12 AM
FSHTAIL
Everything is hooked up properly.
I'm at a loss, anything to check for?
I'm not an electronic wiz..
Ramman
Especially after paint, I would suspect a poor or no ground.
bdschnei
Run a temporary ground from a unpainted spot on the wiper motor to a good engine ground and see what happens.
Bret
Skdmark
Quote from: bdschnei on August 01, 2024, 07:27:18 AMRun a temporary ground from a unpainted spot on the wiper motor to a good engine ground and see what happens.
 :iagree:
-Harlan Ellison
:stayinlane:
The wiper motor gets it's ground through the mounting studs. It's probably where your problem lies.
Grounds are the first thing to fix anywhere there is an electrical component.
 :tool:  :deadhorse:  :wrenching:
