avatar_70rag383
Re-wiring Required
Started by 70rag383, July 18, 2020, 05:52:29 AM
70rag383
Quote from: crackedback on August 07, 2020, 08:45:06 PM
Quote from: 70rag383 on August 04, 2020, 01:53:50 PM
Quote from: crackedback on August 01, 2020, 08:45:49 PM
You are killing the bulkhead connector as Burdar mentioned without a wire around solution.
I build those wires all the time for our mopars.  6 or 8ga wire with a fusible link in it.   Blends in nicely with the OEM harness.
Thanks for the info. Do you recommend routing it via the firewall or via the rad support? How much for yo to make me one?  I'm also interested in taking the headlights off the main circuit and I think you also have a kit for that?
I prefer the factory route.  Crazy as it sounds, the path is just about same length either way.
Yes I have HL relay kits.  4 Headlight systems are 160 + shipping.  Wire around depending on wire gauge are $30-40.   I do discount for multiple purchases.
Let me know
Rob
I would need the 4 Headlight system and the 8 Gauge bypass wire. Can you email me at da.jones512@gmail.com so we can make arrangements. I'm in Toronto, Ontario, Canada.
