Tapping fuse for stereo power
Started by GrandpaKevin, July 08, 2018, 09:26:59 AM
GrandpaKevin
I want to install an aftermarket stereo in the wife's Challenger.
I have very little experience with electrical and wiring stuff.
This will be a very simple system with new JVC head unit with just two 6x9 speakers in the rear factory location.
No amps or other extra speaks.
I want to avoid running a hot wire directly from the battery to a stereo so I would like to tap the power for the stereo head unit off the fuse box.
I am currently using the one aux. power supply on the fuse box for the electric temp gauge and I believe the other one is constant power which I would rather not use.
Am I missing another aux power supply on the fuse box?
Can I just use one of these glass fuse power taps to power the head unit or is there a better way to tap power off a fuse?
Thanks.
That will work for switched power.. there are other connetors in the harness including the original radio connectir
But you will also want a constant power connection as all newer radios need that to preserve memory settings. Same thing on a constantly powered fuse or connector will suffice
GrandpaKevin
Thanks guys.
I did some searching and I think I found the original stereo power plug.
It has power when key is in run and acc.
I would think a male terminal spade connector should fit into the factory female plug?
GrandpaKevin
Thanks guys.
Stereo installed and sounds great.
This is exactly what I will do when the stereo gets installed - re use the factory plug.
