avatar_kawahonda
Washer Reservoir Diagram
Started by kawahonda, July 07, 2018, 08:59:50 PM
Hi all,
I pulled my cracked resorvoir only to find that at the bottom, the pump's threads where broken of into the cone-filter like attachment.
Need to figure out what to order, and how it all hooks up, and in what way.
Already have a new resovoir (came with a grommet installed) but it sounds like I'll be needing some additional mo-parts.
Thanks!
Thanks! Assuming that all I need is the pump and filter?
Thats for you to decide.... Do you have the metal spray nozzles?  The black plastic Tee that snaps to the hood?  The ribbed hoses to connect all those shiny new parts?    FWIW those reproduction metal spray nozzles while pretty & shiny are POS....
Thanks guys. I'll take a picture of the system tomorrow. My current "stop point" is to get everything "under the hood" set up correctly and move on to the many other tasks that are needed. Sounds like I should just get pump/filter and worry about the rest later since the aftermarket set is not good. Plus, they can probably be purchased (better quality) individually.
