avatar_dave73
833 leak at speedo cable
Started by dave73, July 27, 2018, 03:06:28 PM
dave73
My 833 has what looks like a slight fluid leak coming from where the Speedo cable mounts. Any remedies for this? I have a gps Speedo and was thinking of just removing the cable and finding a cap of some sort? Does that exist?
there is a outer o ring & inner lip seal , the inner seal is usually the problem , I suppose you could tap the housing & install a plug or have it welded closed
I've seen frost plugs tapped in there, you never know these days if you can still find one the correct size.
