avatar_Katfish
Gen3 crate motor and controller?
Started by Katfish, August 14, 2021, 03:23:23 PM
I'm learning what's needed to swap in a Gen3 hemi into my Challenger.
Has anyone bought the Mopar crate motor and controller?
I like the idea of a complete ready to install package.
But I see you need to change the oil pan, any other gotchas?
Does the crate motor have all the front accessories needed to run?
I know I'll have to get a compressor if I want to keep my AC.
I just finished installing the crate 392. https://forum.e-bodies.org/your-restoration-project-roseville-moparts/10/a-g-a-r-this-just-in-week-thirty-five/19258/
The motor comes with manifolds that need to be swapped out. I used TTI headers and sold the manifolds for $350.
The oil pan needs to be swapped out, Holley makes a real nice pan, I sold the original one for $100.
I also removed the oil cooler, although it would have fit with my RMS front suspension, I don't know if it fits with a stock K Frame...I sold it too...you need to buy the filter adaptor fitting.
The crate motor also comes with a dual disc clutch and flywheel set-up that won't fit in most aftermarket bellhousings, so depending on your transmission choice, you likely need a new set-up. I sold the original set-up for $1000.
Along with the engine, you need to buy: The control wiring kit with the gas pedal etc..., The alternator kit, the PS pump kit and the AC compressor kit.
Everything available from our sponsor Roseville Moparts  :twothumbsup:
Cuda70-74
U can use the junkyard harness and gas pedal to get it running if u dont want to buy the expensive control pack
1969 mustang
1968 charger
I believe our member Blake makes a great harness as well :thinking: @Blake@diyhemi.com  I was just reading about it in MCG
Thx for the replies, I have plenty of learning to do...........
Blake@diyhemi.com
Quote from: anlauto on August 14, 2021, 04:52:32 PM
Yep, we have harnesses available. I'll be at Moparty this week if anyone wants to check out my car or ask questions
1970 AAR Cuda
5.7 Hemi /A833 ~ DIYHEMI-Cuda
Looking for my numbers matching 340 TA block!
0B289380
www.diyhemi.com
Your late model Hemi swap resource!
