Help in ID this 4 speed?
Started by Brads70, September 07, 2024, 06:43:54 AM
Is this the OD 4 speed? Can anyone help ID the numbers both casting and on the pad?
Thanks Brad
Looks like it , , Alum case , dual shift mount , lever detent , , the front brg retainer should measure 5.2" diameter , only OD had the large front brg retainers
Quote from: Chryco Psycho on September 07, 2024, 08:21:32 PMLooks like it , , Alum case , dual shift mount , lever detent , , the front brg retainer should measure 5.2" diameter , only OD had the large front brg retainers
Thanks.... :ohyeah:
