Help - My 440 Challenger Sounds like a Camry
Started by 777Guy, January 14, 2021, 01:16:40 PM
777Guy
I had a good friend build my 71 Challenger 440 4 speed for me and he did a great job but its not near as authoritive as I would have expected. In fact it sounds like a Camry at most times. I wish we had better contact through that last bit of the build as I know together we could have made it perfect but there was family issues and the project went on longer than expected. We lost contact at some crucial points and I think that's the issue. Anyway, enough drama.
The engine is .040" over has a set of heads are of 74 vintage because we couldn't find earlier heads with hardened seats when we started the project. So basically stock heads..... he put in a Melling SPD-11 cam (intake .283/exhaust .296 and duration IN .050:208/Ex .050:210) I think that's mostly a stock cam and likely one of the reasons it sounds like a Japanese grocery getter. To top it off its stock manifolds and exhaust. Yep, nice and docile.
I have a nicely refurbed 6 pack going in this month and since the intake is coming off I think its time to make it sound a little better. I have a 69 396 Camaro and the ground shakes when she roars.... I like that! Its basically a weekend street car so looks and sound are paramount. The go should be a given with the motor but I'm not looking to race it at all.
I've been poring over header horror stories of fitment and had a few heated arguments with buddies over 3" or 2.5" exhaust systems. Seems I don't need 3" until 500HP, so likely will never need that. So do I need headers? if so which ones are going to give good low end power, sound mean and can be installed without the hand of God helping. Do I need a CAM, if so which one? The finally the exhaust, should I toss it completely and go 2.5" or even larger?
 :welcome: The only pony car of the era that i don't see there is a javelin! nice collection.  :handshake:
I'm no cam guru,  they will chime in soon,  but that's not much cam for a 6 barrel :alan2cents:
I have a lunati I'm very happy with,  703 I think. Need new springs to go with it.
I like Lunati cams. Any idea what your real compression ratio is? What your convertor stalls at? You need 2.5 inch exhaust on a mild 440 like that. 3 inch if you want to do upgrades. TTI headers are the best for fitment but others will work as well.
TTI 1 7/8" headers with TTI 2.5 X pipe and Dynomax Super Turbo mufflers. Fitment is almost perfect.  Combine with Lunati SKU 10230702LK cam and lifters and you'll be happy.  I ran these headers and cam on my 440/512 stroker with a Quickfuel 880 CFM carb, Holley Dominator aluminum instake, ProMaxx aluminum heads with a TTI 3" X pipe until I changed to a custom Bullit hydralic roller cam.  With stock heads you'll probably also need to change valve springs.
Exhaust cutouts will be cheapest. Headers won't do much with such a small cam. Earth pounding exhaust notes comes with higher engine compression ratio and open headers.
Quote from: 777Guy on January 14, 2021, 01:16:40 PM
The the advertised duration initially sounded reasonable but apparently Melling uses really long ramps cause the @.050 duration is ridiculously short....
Something in the 225-235 @.050 would be decent but as Sheldon mentioned knowing true measured C/R would help choosing a cam..
And yes 1 7/8 TTi's & 2.5 exhaust is a good choice....
777Guy
I have to pull the intake off anyway to install the six pack so I should do the cam at the same time, its a pretty affordable upgrade anyway. I've gotten a few suggestions for cam and two seem to stand out the Lunati 702 or the 703. So I think I will change the cam, I think she's just a stock compression with 906 heads. Are one of these cams standout for street driving? I want something that sounds mean but I suspect either one will be a huge improvement over the stockish cam I have now.
Mike
GrandpaKevin
#8
 Welcome and nice Camry!
I installed the Lunati 702 cam in my wife's 440 Six Pack Challenger.
She wanted great street manners and didn't want a super radical sounding idle.
Great bottom end and mid range power and great vacuum for the Six Pack
I would describe the idle sound as choppy, not lopey so maybe look at the 703
I've tried to attach a video of the engine at idle.
https://www.youtube.com/watch?v=lyYhnCKkGGY&feature=youtu.be
This video is my 440 Six Pack equipped 71 Challenger R/T.
The cam is a classic Mopar .528 solid lifter, probably more to your liking but would need more gear and converter (if auto trans), it's not as street friendly and much less vacuum.
https://www.youtube.com/watch?v=LszqkPlY7eA&feature=youtu.be
Welcome From Panama !! :wave:
Overlap is critical , if you go to headers you want 110* LSA
If you stay with manifolds which work just fine stay with 112* LSA
I know the 702 cam has 112* , I recall the 703 is 110*
Lunati makes great grinds for Mopars !
You will need to tune the 6 pack for the 703 cam BTW .
777Guy
Kevin;
Vids are marked as private, can you open the up?
Mike
777Guy
My engine builder dug up the compression ration, says 10.0:1
Mike
GrandpaKevin
Quote from: 777Guy on January 14, 2021, 07:35:48 PM
Mike
While he's digging ask what pistons are in the build & if he knows how many CC's the heads are...  Have the heads or block been milled beyond a clean up pass?
777Guy
GranpaKevin!!
Really?? A pair of plum crazy 440 six packs!?!?! I think either would be a huge improvement! I'm really not kidding too much about the sound of mine very Camry like, stock cam, stock intake, stock manifolds and exhaust.
